Reduce Timing with EGR Removal?
Old 08-07-2004, 12:26 PM
Another_User's Avatar
Default Reduce Timing with EGR Removal?
Have any of you guys timing after EGR removal? I am finally getting all my trims negative, but I have been seeing some part throttle knock retard since the removal (via PCM) of EGR.
Old 08-07-2004, 12:29 PM
HumpinSS's Avatar
I removed mine left timing the same and didnt have any problems
Old 08-08-2004, 07:02 PM
Debian Dog's Avatar
Sure something is not banging around creating false knock? I had to add a spring to my ypipe to keep it from smaking and creating KR. No EGR and all is well.
Old 08-08-2004, 07:20 PM
LS1TECH Sponsor
foff667's Avatar
billiumss had told me the timing table should be altered with egr removal but im not sure where so i have yet to remove it. since ive only got the rights to my 98 i cant view non egr cars generally.
Old 08-08-2004, 07:35 PM
HumpinSS's Avatar
On my car timing is added for the EGR
Code:
0	0	0	0	0	0	0	0	0	0	0	0	0
0	0	1	3	4	2	2	0	0	0	0	0	0
0	0	3	5	6	5	3	0	0	0	0	0	0
0	0	6	7	7	5	2	0	0	0	0	0	0
0	0	4	5	6	4	2	1	0	0	0	0	0
0	0	2	2	5	3	3	1	0	0	0	0	0
0	0	0	0	2	2	0	0	0	0	0	0	0
Old 08-08-2004, 07:39 PM
ataylors's Avatar
timing is added for the EGR, all you should need to do is zero out that table.
Old 08-08-2004, 07:54 PM
Moderator
JNorris's Avatar
What table do you remove timing from?
Thanks
John
Old 08-08-2004, 09:05 PM
ataylors's Avatar
Engine>Spark Advance>EGR Correction Add
Old 08-08-2004, 10:04 PM
slow's Avatar
did you click the disable button for EGR, or simply remove codes?
i was under the impression that if you disabled it by the radio button, it disabled that table, but i could be wrong.
Ryan
Old 08-08-2004, 10:07 PM
7 Second Club
NicD's Avatar
yup
Old 08-08-2004, 10:18 PM
LS1TECH Sponsor
foff667's Avatar
so then whats the concensus? If you delete it via egr enabled/disabled button your good to go and just remove it whether your swapping intakes or just removing egr? Or is there something in the high & low octane tables you have to adjust for? If im set I'll pull that eyesore tomorrow lol
Thanks
Bill
Old 08-09-2004, 12:05 AM
I never quite figured this out. If I remove EGR with the HPTuners option. Since it still throws codes...does it still apply the timing found in the EGR timing add table? I can easily zero it out...
Old 08-09-2004, 10:34 PM
felton316's Avatar
After I removed the EGR on my 98 with an LS6 intake and LS1-Edit. I wound up adding a few degrees of timing (~2). I'm not sure if this was due to the LS6 intake making my engine stronger(or maybe just more efficient) or the lack of EGR.
Old 08-09-2004, 10:57 PM
Where did you add timing? I pulled a little today, and eliminated a good portion of my knock retard. It's hard to be sure...my engine gets knock retard like a **** if I let it get heat-soaked. Now it seems better, just a few degrees to trim.
Old 08-10-2004, 07:50 AM
HumpinSS's Avatar
The tabel i posted above shows you where it is adding timming fo the egr.
Old 08-10-2004, 04:07 PM
Thats a crapload of extra timing. 98s are already aggressive...is that really safe?
Old 08-10-2004, 04:48 PM
slow's Avatar
the timing is safe. IF your pumping in the inert gas, (EGR)
If your remove the EGR, turn it off at the button, and log your timing. since EGR is not a factor at WOT, its not a big deal anyways
Ryan
Old 08-10-2004, 05:28 PM
HumpinSS's Avatar
That is the timing from the EGR add table
Old 08-10-2004, 06:37 PM
Yeah. It turns that extra timing off when you disable EGR. I think it is still too much. I think they factored a little bit of the EGR table directly into the main timing table, and the rest into that EGR table. I removed some timing in some choice spots and I get way less knock retard, and a big difference in knock when you first punch it. I heard a little pinging at moderate throttle, and I think this fixed it too. Too much timing for my temperamental car I guess. I need a 160 stat...I get the most kr when my engine bay gets heat soaked.
Old 08-10-2004, 06:42 PM
Moderator
jimmyblue's Avatar
Maybe you want cold air induction, and/or to play with your
spark vs IAT table. Presuming you have the fans set proper
so that your stock 'stat is maintaining a steady 194F while
sitting, ECT shoulf not be a factor.
Quick Reply: Reduce Timing with EGR Removal?
