what is the cheapest 383 stroke kit for ls1?
Old 08-08-2004, 10:36 PM
fozziejared's Avatar
Default what is the cheapest 383 stroke kit for ls1?
where can i find the cheapest 383 stroke kit? i dont want a piece of crap though maybe eagle or je? let me know if you have found a cheap place to buy this kit. thanks.
Old 08-09-2004, 12:29 AM
Ben R's Avatar
Eagle 4.000" Crank - $990.00
Eagle 6.125" Rods - $550.00
Diamond 3.905" Pistons & Rings - $770.00
Federal Mogul Main/Cam Bearings - $150.00
All that's left is the cost of the small stuff: Gaskets/Fluids/Machining/Assembly/Installation.
Old 08-09-2004, 12:55 AM
jrp
SN95 Director
jrp's Avatar
cheap and 383 are an oxymoron
Old 08-09-2004, 12:53 PM
LSs1Power's Avatar
U wont find anything cheaper than the SLP package. http://www.slponline.com/view_produc...RTNUMBER=12404
Old 08-09-2004, 01:46 PM
Camaroholic's Avatar
I looked in to this for a friend... If you look at Summit, you'll see that Eagle cranks are $790, Eagle H-beam rods with L19 bolts are ~$480, and Ross LS1 pistons are under $700 (with pins & rings). Throw in bearings for under $150, and you're a shade over $2k, shipping included. Not gonna get much cheaper than that without skimping on components. Tack on a couple hundred for machine checking and balancing of the kit, and you're good to go.
Old 08-09-2004, 02:21 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
We have our Eagle/JE kits for $2182 unbalanced, and just a bit more for the balanced kit. They are in stock ready to ship. PM or e-mail me with any questions about specific applications and the like.
-Matt-
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 08-09-2004, 02:43 PM
wildchevy's Avatar
deleted
Old 08-09-2004, 04:31 PM
2000ws6transam's Avatar
i have seen them on ebay for 1999-2299 balanaced with bearings ARP bolts and all the other GOOD stuff!!!
Old 08-10-2004, 12:15 PM
BAD2000TA's Avatar
I'd had been thinking about doing a 383 stroker myself, however, with SLP's ZL402 package coming out, I think I have seen the light. For $3,500 you get all you need. You can then sell the old LS1 motor and get some moeny back. Great deal!
Old 08-10-2004, 09:45 PM
when is this slp kit zl402 coming out? is it the block and all? sounds too good to be true, i wouldnt have to fool with having block bored or kit installed, nothing would have to be balanced sounds too good. will i still be able to remove my zo6 heads and cam and other components and use them on this block? is it just the ls1 pre bored and built up or is it an actual 402 motor? let me know if you know thanks.
im feeling a little overwhelmed with information like drinking from a fire hydrant. haha. thanks guys.
