PCM Diagnostics & Tuning - EGR Removal and Timing Changes
View Full Version : EGR Removal and Timing Changes
BAD2000TA
08-09-2004, 10:27 AM
Hey everybody, I just installed my new LS6 intake and did the LS6 PCV conversion to my 2000 Trans Am this past weekend. Other than breaking the oil pressure sending unit and cutting up my hands reaching under the cowl, it went ok.
One thing I did was remove the EGR, since the new intake was the standard LS6 and not the modified SLP version. I did get the code, which I expected. So, reading some of the posts, I guess the EGR can be eliminated from the computer. How can this be done? I know that LS1Edit can do it, but I don't have it and if I understand how it works, the license is VIN specific.
Also, there are some conflicting arguements that the timing will need to be adjusted after the EGR is removed. I have noticed that the idle is slightly higher when coming to a stop, but it does go down to normal after a few seconds. It's only about 200 rpms higher anyways.
Anybody have any ideas on fixing this? Living in Houston, I know that Jayson and the boys at MTI can fix me up, but $500 for a tune? :eek2: I'd rather wait until putting in a cam and then feeling justified spending that much money. Thanks!
Brian
The Alchemist
08-09-2004, 11:42 AM
If you don't need a dyno tune, and just need some codes changed, you should be able to find someone to do it for a lot less than $500. You should be looking at closer to $50-$100.
Best of luck. Try posting in the regional forumn and see if someone has an HP tuner for your year and offer them a couple bucks to change the neccesary codes. HP tuner is good for unlimited cars of the same model, same year, i.e. all 1999 F-bodies.
Another_User
08-09-2004, 03:07 PM
Hmmm. Mine has always done that. It's not really caused by the EGR, I think that is the IAC throttle follower. I am pretty sure mine always did that stock too.
FCar2000TA
08-09-2004, 03:51 PM
If there's any chance you'll be in Phoenix, I'll set the codes to "no error reported". I have HP Tuners for 2000 F-Bodies.
BAD2000TA
08-09-2004, 10:29 PM
Probably not going to be in Phoenix anytime soon, but I appreciate the offer!
BAD2000TA
08-09-2004, 10:31 PM
Drove out to MTI today. They said $75.00 to delete the EGR code. I can deal with that! Thanks for the reply
Another_User
08-09-2004, 10:58 PM
Man, if everybody would pay me $75 a pop for easy junk like that I would quit my job and tour the US in a winnebago just changing computer codes.
The Alchemist
08-10-2004, 06:51 AM
Yeah, I think $75 is a little high to do 10 minutes worth of work, but I guess they have the justification of the expense of an unlimited license to the software/hardware. I would figure $25 would have been great, $50 would have been middle ground.
At least it's done, now you have no worries.
HavATampa
08-12-2004, 09:16 AM
LOL! I hear you. It's amazes me the prices shops are asking to make such small changes to the PCM. I realize they are in the business to make money and have every right to charge what they want, but give me a break. A local shop by me wants $100 to change the on/off temp settings for my fans. No thanks.
slow
08-12-2004, 09:20 AM
when you have $10,000 in hardware to do the computer editing, and a shop overhead, $75 isn't a bad price at all. ;)
Its easier for the little guy to do some tuning for cheap, but they don't have the $10,000 in software/hardware, and a overhead for shop.
Ryan
