All Baer brake products on sale!
We're offering discounts for ALL brakes that Baer products. This covers everything from their Eradispeed rotors to the complete brake packages!
EradiSpeed™ performance OE replacement rotors deliver more than just "looks.” Every rotor in the EradiSpeed™ program has been purpose-cast, not to the OE specification of the rotor it replaces, but to Baer's specification, with improvements to increase the rotor's ability to survive in hard use. Each is exclusive to the EradiSpeed™ line and has been completely redesigned in a joint venture between Baer and Disc Brakes Australia (DBA®). All are cast with additional, higher quality iron in the "firepath," where the pad contacts the rotor, to provide a more substantial heat sink. This has two distinct benefits. First, every EradiSpeed™ rotor can be pushed farther in hard use before it heat soaks. Second, EradiSpeed™ rotors also provide greater durability. Claims of "improved durability" are often made or implied by other manufacturers, but Baer backs its claim with the industry's only "Limited Lifetime Warranty, against Warping."
Surfaces of EradiSpeed™ rotors are then crossdrilled and slotted. Unlike others who sell “cosmetically altered” rotors, Baer employs a “reverse rotational pattern” which is the standard in racing, world wide. This detail ensures that when the rotor is used with an aggressive pad, the material which transfers from the pad does not “smear” and “collect” following the slot. This is because the counter rotational slot drives into the pad, which keeps the pad “loaded.” In addition, every EradiSpeed™ unit has the crossdrilled holes located behind a vane to arrest hairline fractures and maintain the highest rotor integrity.
The complete brake packages (rotors, calipers, lines and hardware) include everything that you'll need for a high quality install. You can go from mild to wild with these! Options range from 2 piston PBR calipers to wild 6 piston calipers that are made by Alcon. Baer's Select systems allow you to "build your own" package and choose caliper and rotor hat colors.
Details for each can be found on our website. Just give us a call or e-mail for pricing.
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763)
Order line - 1-877-4-TBYRNE
Send us e-mail
Price Match Plus policy
