New LS1 Owners - Newbie Tech - first time driving car with spec 3i, moser, and 160 stat
procharged
08-09-2004, 10:47 PM
I just got finished installing these-and new water pump and BMR and torque arm.- I quess with the 3.73s and the aluminum flywheel, i can tell the car is faster already, a lot more bottom end and midrange. Havent really got into boost yet, maybe a pound, but i can its gonna be pretty sick. Also ZERO chatter with this clutch so far I would def. recommend it. It took about 10 min. to get used to and its so easy to get it not to chatter unlike what a lot of people say. I did stall once but that was cause its like a light switch- but still- not as bad as i thought it was gonna be.
jrp
08-09-2004, 11:00 PM
sweet, my spec 3 and aluminim flywheel are going in as soon as i finish up the new motor. is the clutch slippable (if thats a word) at all?
BlueSix
08-09-2004, 11:06 PM
Who needs slippable.....9", 4.56 gears, spool, 28" ET drags, 6500 RPM, release clutch...... :devil:
As streetable as i have heard the clutch is, i would bet you can slip it when necessary.
procharged
08-09-2004, 11:07 PM
ya actually it is a little little bit. Its almost like stock but ive learned to just let the clutch out a little faster. Youll like it. Did you get the i option- cause ive heard that this helps with less chatter. I dont know what a normal stage 3 feels like but the 3i I cant complain. Also i didnt put the shim in. ive heard different things about it, but i got the new flywheel and it seems to be perfect so far.
procharged
08-09-2004, 11:10 PM
jrp did you ever get them dyno sheets- just wonderin if my phone actually sent them
jrp
08-10-2004, 10:59 PM
:cool:. i just got the regular spec3 x-pad w/o the "I" option.
ya i got the pics you sent, but since they were just the numbers and not the graphs i didnt post them up.
NOBR8KSS
08-11-2004, 01:58 PM
What is the "i" option and where can I find info on the x-pad? Neither of those items is one their website.
I even used the "Search" feature just for you jrp ;)
