Spring, Retainer & keeper recommendation
Old 03-26-2003, 09:22 AM
SSh
SSh's Avatar
Default Spring, Retainer & keeper recommendation
What would you recommend for a Comp Cams - 216/220 .525/.532 114 LSA cam. I will probabaly not ever change to a larger cam in this setup and don't plan to spin it over (or much over) 6200.
Would LS6 springs work OK (which year)?
Can I use the stock 2001 LS1 retainers with the LS6 springs.
Would it be worth the weight savings to use titanium retainers with either LS6 or Aftermarket springs?
Thanks in advance,
Scott
Old 03-26-2003, 09:33 AM
Paul F's Avatar
Default Re: Spring, Retainer & keeper recommendation
I would recommend the Comp 26918 with stock retainers and keepers.
Old 03-26-2003, 10:34 AM
Brian Tooley Racing's Avatar
The 26918 would work, and you would'nt really see any kind of benefit of using the titanium. Just make sure you have enough seat pressure with the spring and you won't run into any kind of valve float at 6200-6500.
Old 03-26-2003, 10:44 AM
SSh
SSh's Avatar
Thank for the input, I was think about the 26918s. Can I just install these as is or do I need to be concerned with installed high and seat pressure?
thanks again,
Scott
Old 03-26-2003, 10:52 AM
Paul F's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSh:
<strong> Thank for the input, I was think about the 26918s. Can I just install these as is or do I need to be concerned with installed high and seat pressure?
thanks again,
Scott </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If the heads are bone stock then you could just drop them on and spring pressure should be fine. It would hurt to check one or two but it's not that critical with stock heads and a 216/220 cam.
Paul
Old 03-26-2003, 11:20 AM
Zeta's Avatar
<strong>
Thanks in advance,
Scott </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">There is about 7g less mass in the Ti part. 7 * 16 = 112g / 4oz less mass with Ti.
The seat pressure is 90 with the 02 z06 spring, vs 130 with the 918 spring.
I do not know the mass difference between the stock and the 918.
I do not think you will ever get empirical evidence that a 02 LS6/z06 springs and Ti retainers are bad in the lift/RPM range you suggested. Just the advice that this ____ is better. When you go over .551 lift with the 02 spring you are over the 02 stock LS6 lift.
<small>[ March 26, 2003, 11:23 AM: Message edited by: Zeta ]</small>
Quick Reply: Spring, Retainer & keeper recommendation
