need help on drag tires?
ok, once i get the 12 bolt, with 4:10 gears. what size tires should i use or get? i have a bolt on m-6 camaro. its a pretty light car. lt' headers and alot of bolt ons. 3:73 gears in a 10 bolt. best et so far is 11.67 @ 118.20 on et streets, and on nittos it was 11.77 @ 118.90. thanks for the help.
<small>[ November 08, 2002, 10:55 PM: Message edited by: LARRY01Z28 ]</small>
Re: need help on drag tires?
A 26" tire would take you through the traps (using 120mph) at between 6300-6400, which sounds about right for a bolt-on LS1.
A M/T ET Drag 26x10.5x15" tire would probably work very well.
i agree, 26x10 et drag would provide a little better traction than a et street. you could also go with the 27x11.5 hoosier qtp's like me and moose run.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by EVIL:
<strong>i agree, 26x10 et drag would provide a little better traction than a et street. you could also go with the 27x11.5 hoosier qtp's like me and moose run.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do the hoosiers hook real good? I used hardtops, et streets and they felt wesome. but i think there is more traction to be had once i get the 12 bolt. i want to be able to leave the line and cross the 1320 right at redline. but i dont want to do heads and cam yet. thanks alot guys. anybody else got any info?
moose got a 1.52 on them that day at mir. i got a 1.51 on the spray on them. they seem to work noce if you have the gear for them. moose runs the 4.30's in his car on them, but with 4.10's, you should cross right at 6100-6200 with no problem.
Moose and Evil I just changed to 27x11.5x15 QTP and I like them also. I ran 1.53 shortime and 11.67 with a stockhead stockbottomend Lt1. I run the tires with no tubes. I now have 22 runs on them with a 1.55 average shortime. Frank95z
frank95z, thank you for your reply. I think i will go with the QTp's i seen a price of 170.00 for them. ill check around and see if i can get a better deal. thanks alot everybody. if anyone else has anything to add th this thread please do. imnew to the world of actually getting good launches. im a nitto guy. so all the help is appreciated.
