What is your best 60/ft on Nittos with a M6?
Re: What is your best 60/ft on Nittos with a M6?
1.92! <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> I'm just too scared to launch any harder on the stock rear w/3.42's! That was with 245/50/16 Nitto's. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Mine was a 1.92 also on my stock rear with stock clutch, I did not want to push it any harder on the stock rear.
This was done with 4.10 gears in stock 10 bolt with a rearend girdle and 85/140 royal Purple gearoil for extra cushion. Centerforce duel friction clutch. I use to just clean the tires off and pull 1.90's but seen a freind hook hard by doing a big burn out and now so do I. My 60/fts stay in the 1.7's for the most part and dip in the low 1.7's if I get aggressive( 4200 rpm's and dump).Check sig for more on my set up. new best is 11.75 @ 118.49 mph with 1.72 60/ft
<small>[ November 11, 2002, 04:06 AM: Message edited by: AINT SKEERED ]</small>
1.73 and a 1.77, stock clutch and 3.42s! Running 275/17 BFG DRs. John Force burnouts work <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
But I done for the year, at the limits of the stock drivetrain <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
<strong>my good friend Larry01Z28 cut a 1.70 or 1.71 I think on nittos.. lead to a 11.7@118 pass stock internally</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">hey thats me, lol thanks Harold
I got a best of 1.709 11.807 @ 117.03 at VMP
then a 1.748 on a different day i went 11.779 @ 118.90 than wsa at MIR
Hope this helps.
Hope this helps.
damn I must suck at launching <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
My best 60' time was a 2.2 on 275/40/17 nittos and thats with a lot of spinning. I've got stock 3.42's with a star stage 3 clutch.
Myabe its because i have a burnt posi and only 1 tire spins <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSilver:
<strong>damn I must suck at launching <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Myabe its because i have a burnt posi and only 1 tire spins <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">dont say you suck. it just takes alot of pratice. get the posi fixed and then try again.
On a good hooking track I run 18 psi in the nittos, and on a not as good track I run 16 psi. It does take a good burnout to work though. I also recommend to go aruond the water and back into it with the rear tires and then roll forward untill you are out of the water to start spinning ,for those that did not know. Chad
Um NITTO"S SUCK!!!!!!!!!
Nitto 60ft> 1.94
Street tires>1.89
BFG DR,s>1.75 clutch slipping <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
BFG DR's>1.79 no clutch slipping with a bog
3.42 gears
Nitto 60ft> 1.94
Street tires>1.89
3.42 gears
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Zturd:
<strong>Um NITTO"S SUCK!!!!!!!!!
Nitto 60ft> 1.94
Street tires>1.89
3.42 gears</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Umm...maybe you just suck at driving?
AJ
Nitto 60ft> 1.94
Street tires>1.89
AJ
Nitto 60ft> 1.94
Street tires>1.89
3.42 gears</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">1.70's on nittos for me so i say they dont suck. you just have to know how to launch them. every tire is different. you just need to know how to launch what ever thire you choose.
Nitto 60ft> 1.94
Street tires>1.89
