Sponsor Sales & Specials - Pro-M Mass Air Sensors $269.95 shipped !!!
Mike @ New Era
08-11-2004, 12:26 PM
This includes all LT1 and LS1 applications .
Pro-M manufactures General Motors LT-1s and LS-1s, then calibrates them to strict specifications. Parts are made to fit with no modifications to the vehicle, and are ready out of the box. LT-1 and LS-1 meters are made of a high-temperature glass-filled nylon, the housings are injection molded and then fitted with modified OEM elements. Pro-M modifies each LS-1 meter by machining and re-facing the inner diameter. After the meter is bored out, it must be re-flowed. Each and every meter, whether LS-1 or LT-1, is individually calibrated on Pro-M’s state-of-the-art flowstands. When the meter has been set to optimal aftermarket specs, it is sealed and packed for its chance on the track. Pro-M is the only aftermarket company that has succeeded in calibrating MAF meters with the same accuracy as the OEM part. Put one on your vehicle and feel the difference today.
Thanks ,
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
