Drag Racing Tech
Any one running PETE Z bars?
Old 11-17-2002, 02:54 PM
TOSTO RACING's Avatar
Default Any one running PETE Z bars?
Just wondering how they were thinking of getting a set.
Old 11-17-2002, 03:15 PM
wicked 98z's Avatar
Default Re: Any one running PETE Z bars?
I know of 2 people in the houston area that are running them. And form what they tell me they like them alot.
ALbert
Old 11-17-2002, 03:31 PM
Thanks
Old 11-17-2002, 04:12 PM
SPANKY LS1's Avatar
I have heard of these, where can find more info and where can I get them from? Thanks, Shawn
Old 11-17-2002, 04:27 PM
chevyguy3's Avatar
im pretty sure Tim (posts as 95 Formula on this board) is using them
Old 11-17-2002, 04:49 PM
Fenris Ulf's Avatar
What are the Z bars?
Old 11-17-2002, 05:22 PM
JimmyKash's Avatar
http://www.madmanandcoracing.com/low...rolarmkit.html
no offense, but do a search. There was quite a lenghty thread about them a while ago
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 11-17-2002, 09:50 PM
95 Formula's Avatar
I have them and I'm still trying to figure them out. I think I have a handle on it but need a long day at the track to try some final settings. On the street they aren't too bad..if you have adjustable shocks. Turn them ot 0-2(soft) and the ride isn't too bad. In race setting(6-7 for me right now) if the return road is bumpy you will almost hit your head on the roof if it wasn't for the 5 pt. I like them and think once I get my suspension set right will be in the mid 1.4x with a 6 speed. I know judson went 1.29 with them at the thunder shootout and alot of stock elem boys run them. Sometimes I wonder why I got them..sometimes I love them..lol. I think on an auto you would elem any hooking problems you have. Last time at the track hardly anyone was able to hook except the big tire converter cars. By the end of the night Ihad set a new best 60' on a so-so track prep. So it looks like they are starting to do what they are suppose to do.
Tim
Old 11-18-2002, 11:56 AM
Y2K_WS6_T/A's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TOSTO RACING:
<strong>Quickest stock internal m6 (2001ss)10.95 at 122</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry to get off topic, but is that ET/MPH N/A? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Mir Naziruddin
Old 11-18-2002, 01:11 PM
SSU Moderator
RyanJ's Avatar
TNT wet kit.
Old 11-18-2002, 05:51 PM
No that was a tnt 100 shot, 4.10 gears, flowmaster muffler,centerforce clutch,and et streets.Everything else was stock I didn't even have headers on the car then, and it weighed 3610 race weight.That was also over a year ago.
Thanks for the info on the bars.
Old 11-19-2002, 10:58 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Doesn't Doubsta's BeaSSt have those bars?
Old 11-19-2002, 10:59 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>Doesn't Doubsta's BeaSSt have those bars?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">YES
Old 11-19-2002, 03:53 PM
WIKIDTA's Avatar
I found some more info on these bars that may help you and another picture.
<img src="http://hpspecialties.com/graphics/productATE-101_fullsize.jpg" alt=" - " />
can also be found at:
hpspecialties.com
ATE-101 is the part number. Location is in the PRODUCTS section under CHASSIS
"These high quality traction bars are a laser cut assembly, made from top grade billet aluminum link tube and high strength spherical rod ends. This setup is completely bolt on, designed to be used in conjunction with factory torque arm, converting stock trailing arms into a short ladder bar system. These ladder bars are track tested by national event and class winners. Legal and approved for NHRA and IHRA stock eliminator and bracket racing."
The price on that site is a little bit expensive. I would get the bars from Madman. The pic of his bar is identical to these bars and probably cheaper.
If you need more info and want to contact Pete Z himself...here is the number I found. Call Pete Z at: 315-483-6412
Hope that helps.
<small>[ November 19, 2002, 04:15 PM: Message edited by: WIKIDTA ]</small>
Old 11-19-2002, 08:49 PM
Thanks for more info.
Old 11-20-2002, 07:26 AM
GeorgeC's Avatar
Anyone know why they're for use with a "stock torque arm?"
I wonder if that means a stock type torque arm suspension in general, or literally a stock torque arm.
<small>[ November 20, 2002, 08:12 AM: Message edited by: GeorgeC ]</small>
Old 11-20-2002, 07:35 AM
LS1Tech Sponsor
MADMAN's Avatar
These bars are ffor use with a stock t/a because you need to let the t/a float. We usually take a piece of 2x3 tubing and stand it up on a crossmember. We put the front of the stock t/a thru the tubing and let the arm float in there. The only thing the t/a does at this point is if you ever break the "Z" bars the rear end will stay under the car. I DONOT recommend these bars for street driving because of the noise factor. They hook extremely well on stock eliminator style cars.
__________________
225-343-9029
Old 11-20-2002, 08:13 AM
GeorgeC's Avatar
Thanks for clearing that up, Brian. It makes sense, now.
I'm happy as could be with the Madman TA, so I don't think I'll be changing any suspension components anytime soon. I may have to install a wheelie bar, though. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 11-20-2002, 09:20 AM
JimmyKash's Avatar
couldn't you run the stock t/a on the street and un hook the rod end from the z bars?
then let the t/a float at the track and hook up the rod end again?
Old 11-20-2002, 10:52 AM
rnr27band1's Avatar
can someone post of pic of these installed? i am still not fully grasping the concept here and i think a pic might help.
Quick Reply: Any one running PETE Z bars?
