Help,02 sensor circuit high volts?
This is the code my car is throwing now, I fixed everything else. I thought maybe I had a bad connection since I cut the 02 sensor in half and extended it with some wires so I redid it all the same way, made sure everything was hooked up good and it threw the code again. Whats the deal?
wrencher
Other than what jimmyblue said which is likely..Your not post to splice the wiring on the O2 sensor. It has corrision/heat resistant wiring & doesnt solder or butt connect well at all. You should always use extentions IMO to keep from having problems.
