Larry
08-13-2004, 08:15 AM
I have Morose 26 x 4.5 x 15 DS-2 front runners. The side wall says 32 psi max. At 32 the tires look low. How much pressure can you safely run?
PHIL H
08-13-2004, 05:56 PM
I pump my et fronts up to 42 to 44 sometimes..The stock eliminator guys do that when they have a "heads up race".
Larry
08-13-2004, 09:19 PM
Your ET's are probably about the same design as my Moroso so I should be able to run more than 32. I got a little concerned when I read the tag on them that said no more than 35 to seat the tire.
chpmnsws6
08-14-2004, 02:03 AM
it will look kinda flat but its fine. its just alot of weight on a tiny tire
