How much HP is 1 point of compression worth..
Reason I ask is that on my stock shortblock I was running roughly 11.3-11.5:1 compression. With all of the same components (well a different spec cam for the turbo), on a forged 6.0L I am running 8.8:1 compression. I'm just curious how much the compression drop would affect my NA RWHP. Losing around 2.5 points of compression the new engine feels a lot stronger then what I was expecting.
-Sly
-Sly
I have always used the 4% rule.A while back one of the magazines performed a engine dyno test,with the same motor,and changed the compression in 1 point increments.The test turned out to back up the 4% rule of thumb.
4, add, compresion, compression, drop, horespower, horsepower, hp, ls1, ls1tech, ls6, point, pointof, points, worth
