Trans temp sender?
It really doesn't matter IMO, just so long as it is not on the return line from the cooler (false reading). Now if you were installing a pressure gauge, then I would definately place it on the capped port on the driver's side of the trans.
I'm in the process of installing a mechanical trans temp gauge, It looks like the pressure port on the side is to small for the bung that is included. Do I have to drill the pan or get an adaptor to put it in the side?
