About how many miles can I get off of my dual springs?
I don't drive the car to the extreme all the time, but it gets driven hard from time-to-time I have the dual springs that came with the heads from MTI and I'm running a G5X1 cam 228/232 .588/.575 (Hell, I'm not even sure which brand the valve springs are ) But anyways, I'm just trying to see how many miles these things should get out of normal wear and tear.
Thanks,
Nathan M.
Thanks,
Nathan M.
They should be checked and measured every 15k miles. It doesn't mean you'll change them but it is part of aftermarket maintenance.
I think MTI uses Manleys but I'm not certain (Their valvetrain package specifies Manleys).
Originally Posted by Viper
I got 11K out of my ISKY 295D dual springs.
I would go with a real dual spring like the Crane's, Patriot's, or the Comp 921 for that added insurance of a dual spring and check them at 15k like Predator said.
Originally Posted by blazeone
Your MTI heads use Ferrea springs matched to the Ferrea valves, very stout.
Anyways, I would have the Ferrea springs checked at 15k like with other dual springs.
