WhAt other springs
WhAt other springs
I put a set of prokits all around on my 35th SS LE now my 295/35/18's are rubbing the rear outer lip and not just by a little either I put a 7/32 spacer and used a hammer b/c they were hitting the inner fender. Because its a 35th LE I don't want to roll the lip. What other springs could I swap the rears out with so they are a little stiffer and don't have as much drop as the prokits. If necessary I will change the fronts too if that's what is recommended. What is the rear drop of the prokit? Should I go with something like a 1 inch drop or a 3/4 inch drop should I put my stock spring back in? PLEASE HELP I also forgot to mention I put a set of revalved Bilstein's in that I got from Stranos. Please give me some feed back. TIA
