Nitrous Oxide - Direct Port -- TNT Ring?
View Full Version : Direct Port -- TNT Ring?
beardWS6
08-15-2004, 11:19 AM
I have the TNT ring and love it. I`m planning a Stroker and was thinking of going to a direct port. I know you can run my kit up to 200 shot and thats it safely. Anything over that and you need a direct port. My question is if you have a 200 shot with the ring, and same with direct port is the power the same! I might even go to a 250 shot. I`m going to wait and see. Thanks!!
Navy David SS
08-15-2004, 12:12 PM
Just upgrade to the TNT F2 kit. It's from 150-250 shot. Not sure on extactly what the upgrade would be - poss solendios, jets and line ????
David
turboo16
08-15-2004, 06:20 PM
David
TNT F2 kit does 150-350rwhp the F1 kit does 75-250rwhp so you decide a directport will hit harder
Turo
08-15-2004, 06:23 PM
my F1 kit only brought jets 75-150, can it support a 250 shot?
Navy David SS
08-15-2004, 09:24 PM
That was my point. The F1 is 75-150; F2 is 150-250 (per TNT Site). I "believe" the difference is selenoid, jets and a bigger nitrous line. But someone would need to ask TNT. Anything above 150 is a bit much for my stock bottom end out of the hole - now a 2nd stage 50-100 shot dry in 2nd gear may be a different story.
David
v8-7
08-15-2004, 09:27 PM
i'l buy your power ring setup... :)
