should I port my stock heads?
Old 08-16-2004, 12:01 PM
JDPZ28's Avatar
Default should I port my stock heads?
Well, my car is immobile right now due to a busted 10 bolt , so I was thinking while it's sitting should I go ahead and take off my heads and send them out to get a port/polish? I found a shop here in NC that can do it for around $600. I am pondering this option because I am about to spring $2,000+ on a new rearend and can't afford another $2k for the AFR's right now. What would you do?
Old 08-16-2004, 12:06 PM
buymeavette's Avatar
suspension mods to go along with the rear end would help
Old 08-16-2004, 12:18 PM
TD's z's Avatar
600 bucks for ported heads sounds pretty scarry what does this include?
if i were you i would save up untill i had the money for a pro to do it
are you just looking for a stage 1
you shouldn't totally give up the idea of a gm casting we've been getting some pretty impressive numbers out of our very recent 5.3 and even 5.7 stuff flow bench and dyno
Old 08-16-2004, 12:46 PM
JDPZ28's Avatar
here is the link.about halfway down the page under other options. I was looking at the econo port or even possibly the full port.
http://www.advancedinduction.com/AiProductsLS1.html
Old 08-16-2004, 12:48 PM
JDPZ28's Avatar
I do have BMR lca's and panhard rod. I guess I need to update the sig.
Old 08-16-2004, 01:51 PM
silverbeast's Avatar
hey JDP, i just looked at your pics and i have a few questions. where is holly springs , i looked on the map and all i found was holly ridge. down at the coast. i live in the middle of nc at the very top. anyway which cam did you like the best, the fm13 or the lg x2. i really want a cam but i cant make my mind up. i have about the same mods as you. i think i want the g5x3 or the fm11 or 13. one of those. and what kind of times do you run? oh about the porting on your heads. we have a guy up here that ports heads and might do them cheaper than that. he does all the head porting for a race shop up here. they have the worlds fastest neon and a nova that is bad also. anyway shoot me a pm if you want me to get a price for ya. later charles
Old 08-16-2004, 02:04 PM
JDPZ28's Avatar
sent you a PM.
