Nitrous Oxide - What are some typical numbers for these setups?
BlackMagicC5
08-16-2004, 01:39 PM
I'm doing a little research, so maybe someone can help me. What are some typical rwhp numbers and rwtq numbers for the following setups.
1) WS6 stock, with a 150 shot.
2) Camaro SS stock, with a 150 shot.
DeepBlueZ
08-16-2004, 02:05 PM
the numbers would be the same for both cars as there isn't any meaningful difference between an LS1 WS6 and an LS1 SS on the dyno. i would bet around 430-440 RWHP depending on tranny and type of system.
Navy David SS
08-16-2004, 02:06 PM
A blown engine :bomb:
If taken easy and tuned, with suspension, there is one WS6TA running 10.26's.
Normally: most LS1 stock will pull 320-330 rwph -- if you go with a wet-system (TNT is my choice) 150 shot will get you close to 150 rwph - so a guess would be 470-480 rwhp (totally stock). Add a couple of mods - poss close to 500+ rwhp.
David
