Any dyno #'s for 3" cat back vs.x-pipe to 3"duel bullets?
I made the swap to a x-pipe to 3" duel.At the track I seen no gain what so ever.Just louder.Tell me it's in the tune.I have to go back next monday for a re-tune.I'm gonna bring my 3" cat back just in case my #'s dropped so I can pull the car on the trailer and swap out the exhaust.In my mind the x-pipe set up should make more.any dyno proof out there to put me at ease.
No gain in mph. I did some other changes since my last outing-clutch,k-member-skinny's up front and x-pipe to 3" duels.Only seen a 1 tenth quicker ET with a better 60ft and the same mph.I'm installing my racetronics fuel pump this week and 42lbs injectors and have a shaner S3 to compare against my BBK, next monday it goes back for the re-tune.I hope it's all in the tune.That one tenth quicker I went is from the k-member, lower control arms and skinny's-no gain from x-pipe
I went true dual route for the sound. I didnt think there would be much difference between y pipe versus a dual system. Most y pipes out today flow pretty decently. My thinking was that the idea of diminishing returns comes into play with these exhaust setups when comparing a good flowing y setup to a dual. I also wouldnt think you will gain much with a tune unless the original tune was off.
Originally Posted by HC02SS
I have a graph from going from SLP Dual/Dual to 3" bullets dumped. The only other change was stock TB to S2. Peak numbers went from 378/363 to 380/378. The area under the curve was awsome. I will try and relocate that for you.
Originally Posted by 02SOMWS6
It has to be the tune,has to be. Thats what I keep telling myself cause the money spent on the x-pipe to 3" could have been put towards a TNT kit.
!LS1 11 Second Club
Originally Posted by JS
Test them against a 3in single system w/cutout and guess what your gonna see..
The single 3in w/cutout BLOW the true duels away.
JMHO but I dont believe there worth anything over a single w/cutout.
When I had a Y catback and cutout (open), my car was dead 'till about 3000 rpms. The duals sure did lots to put some power back in the low rpm dead zone.
Peak vs. Peak the cutout vs. duals will be similar. Area under the curve improves with the duals.
LS1Tech Premium Sponsor
We tested a open cutout car before & after true duals & the duals made within 2-3rwhp peak & made a little more in a few places down low. I kind of just look at it as the ability to run open cutout power with good sound
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
