Is 108k miles too many for a cam install??
Old 08-16-2004, 11:06 PM
Ellis Juan's Avatar
Default Is 108k miles too many for a cam install??
Fm13 cam going in the car. Or should i change and go with nitrous until the motor goes. Some guys have said rebuild and that 108k miles is too many. They were all interstate miles driven by a girl. miles are miles i guess, although i would rather have my sisters miles over my own . I Think it should be ok. Any thoughts
Old 08-16-2004, 11:11 PM
2 SLOW's Avatar
DO IT!
/starsky & hutch
Old 08-16-2004, 11:18 PM
LS1TECH Sponsor
foff667's Avatar
i wouldnt worry about the cam being the downfall of the motor...id start looking at replacing many of the other parts while your in there though ie oil pump, timing chain, PR's, possibly rockers.
Old 08-16-2004, 11:20 PM
FASTONE's Avatar
If you aren"t having any motor problems say smoking or burning oil I wouldn"t worry about the mileage,put the cam in it and enjoy!!
Old 08-16-2004, 11:23 PM
FASTONE's Avatar
Good idea,I agree!!
Old 08-16-2004, 11:27 PM
fastsspr's Avatar
You are rigth Fastone if the motor is bad it going to let you know giving you warninig like smoke,sound,etc.If you feel everything is rigth with you car go for it and do the cam change.I think a good idea to is to replace the timing chain and oil pump.
Old 08-16-2004, 11:32 PM
Onyx Z's Avatar
105k here and just installed a cam. I have no wierd noises, ZERO burning of oil, and no smoking. Just be sure to replace the oil pump, timing chain, pushrod's, and the springs and you should be set to go. Enjoy!
BTW, what's the specs on that cam?
Old 08-16-2004, 11:38 PM
2 SLOW's Avatar
230/232 591 585, if you already have great oil pressure (50 at idle, 60+ at WOT) is it worth it to get a new oil pump?
Old 08-16-2004, 11:41 PM
Onyx Z's Avatar
Ehh, that's kind of a personal thing. I personally would do it, for peice of mind mainly. And I have heard of the pre 01's failing for no reason.
Matt, what does your oil pressure read at idle when it's hot?
Old 08-16-2004, 11:42 PM
2 SLOW's Avatar
60 psi at start up, and whats the big deal with replacing the timing chain?
Old 08-16-2004, 11:43 PM
Onyx Z's Avatar
They stretch out over time.
Old 08-16-2004, 11:44 PM
2 SLOW's Avatar
damn, so all u have to do is purchase a new timing chain? no other little parts to go with it?
Old 08-16-2004, 11:49 PM
Onyx Z's Avatar
Nah, just the chain, and if you do an oil pump, be sure and change the o-ring.
Old 08-16-2004, 11:50 PM
2 SLOW's Avatar
f the oil pump, my pressure rocks, where did u pick ur timing chain from?
Old 08-16-2004, 11:56 PM
Onyx Z's Avatar
My timing chain came form my work. Hit me up on AIM if ya wanna talk.
Old 08-17-2004, 02:03 AM
God of Thunder's Avatar
beware of the o ring!! i just put the an F13 in my car (78k), finishing up tomorrow. but i have to say, that o ring is a bitch!! trust me, the oil pump is a pain to get lined up, and for me the o ring kept falling off! goodluck though.
Old 08-17-2004, 02:33 AM
pdd
pdd's Avatar
go for it
Old 08-17-2004, 03:19 AM
PREDATOR-Z's Avatar
When putting a cam the size of the FM13 (Revs till 6800 and more), it puts a lot of stress on the bottom end.
It is usually the rod bolts that let go from being fatigued.
Put it all on paper and see for yourself all the parts on top needing replacement and do the math.
Cam/valvetrain $1000
oil pump $130
Double Roller $120
Gaskets/Bolts $80
Lubes/oil $50
Rockers $320
Total $1700 not counting tools.
This doesn't change your lifters that could collapse on such high lifts, rod bolts, tired valve seats etc......
Good luck!!
Old 08-17-2004, 03:26 AM
LSX Mechanic
Damian's Avatar
Buddy of mine installed heads/cam on his 150K mile shortblock. Runs fine....
Do it, just make sure to refresh a few things while you're in there. Chain, Oil pump, etc..
Old 08-17-2004, 07:59 AM
Ellis Juan's Avatar
The car runs awesome(knock on wood). Great compression all across the board and burns no oil. Timing chain, oil pump, rockers and lifters were all figured into my budget. Im a "while your in there might as well" kinda guy. Only thing im worried about is the tune. What do i do since i just have the stock computer i.e. no ls1 edit? Ive been deliberating for weeks between the g5x3 and the fm13. Hard choices, but i figure they are both really awesome cams so either is a great choice.
