Need info on location of sending units..
Those of you that have non-stock electric guages, where are you putting your sending units for them? I have a two guage pillar pod and water temp and oil pressure gauges. Thanks for your help!
Water temp goes in the block above the starter. The starter needs to be removed to get access to the plug. You will also need a M16x1.5 adapter. The other location is in the head by the #8 cylinder. Not easy to access.
Not sure about oil pressure. I think it goes somewhere around the filter, but search to make sure. And why do you need one anyways? You already have one
