Is the stock tach off?
Old 08-18-2004, 08:37 AM
v8maro's Avatar
Default Is the stock tach off?
I installed a shift light yesterday, I set it to 6400 and the light comes on when the tach shows 6k...is this normal on ls1's?
I've had a tune, so I don't know if that matters or not.
thanks
-Steve
Old 08-18-2004, 09:04 AM
hourang's Avatar
stock tach is slow
Old 08-18-2004, 09:07 AM
c5ls1vette's Avatar
The stock tach is off and gets worse the more power that you have.
Old 08-18-2004, 09:25 AM
AnthonyR's Avatar
I agree...the higher up in rpm's you go the more off the tach is
Old 08-18-2004, 09:27 AM
2MuchRiceMakesMeSick's Avatar
Mine is 150 rpms off at idle alone
Old 08-18-2004, 09:48 AM
v8maro's Avatar
I'm talking like 500rpm's here...
if so, at the track I have been really going past my peak and shifting real late
Old 08-18-2004, 10:15 AM
LS1TECH Sponsor
badpewter-z's Avatar
it is extremely slow and more power = quicker reving and it cant keep up just go by the light i think mine is barely at 6k if that when i shift at 6.5-6.6k
also if its regular tpye light(incadescent like autometer) it will be a lil late to just becasue they dont light up fast enough, if its led then its right on . the tach will get closer to accurate when in higher gears like 4th , 5th 6th,
lower gears it just doesnt keep up
keith
Old 08-18-2004, 10:19 AM
AZ28DRIVER1's Avatar
I like the idea of just adding a shift light but keeping the stock gauge for a stealth appearance. What type of shift light set up did you use and how did you wire it?
Old 08-18-2004, 10:25 AM
v8maro's Avatar
Ok, I have an LED type and I will use that to shift from now on, I had no clue before.
I got mine at Raptorperformance.com and I installed mine like this:
Mine has a black housing and yellow LED's, and I love it. Awesome product.
-Steve
LS1TECH Sponsor
stock tach, aftermarket ones arnt my style, and i have a raptor shift light, very easy to wire, power ground, and a tach signal to terminal 10 at the pcm 1/2 hour to put in , mounts almost anywhere too, pillar , vents, colum , dash , ou get the idea, small too
