Crank Position Locator Wheel Movement
Old 08-18-2004, 04:19 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Default Crank Position Locator Wheel Movement
How much 'play' in the locator wheel on the crankshaft is normal or within tolerance? I am having my crankshaft rebalanced and the person said it moves about 0.010" from side to side. TIA.
Old 08-18-2004, 04:21 PM
ls1290's Avatar
Also, the motor that the crankshaft was in did not have any problems prior to removal. When it was removed, it was taken directly to the machine shop.
Old 08-18-2004, 04:27 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I think that some stroker cranks have more than that.
Old 08-18-2004, 04:39 PM
ls1290's Avatar
The crankshaft is a 4.00" Scat billet crank. Thanks for the info John.
I am almost thinking that I will do the assembly after they get done rebalancing and checking the bore diameters and main cap diameters
