Thunder Racing Adjustable Belt Tensioner
I had a problem with my belt walking a few notches over at high RPM's, I even threw it once. My tensioner wasn't bad, it had a lot of spring, it just seemed like it couldn't keep up past 6500 RPM. I picked up one of Thunder's tensioners on the way home from work and the problem is fixed for good. Really good quality piece, lets you get the belt as tight as you'd ever want it. No more throwing belts
Did you have any problems with the tensioner squeeling at all?
Mine does, but its very random...kinda wierd I think, very inconsistent.
Originally Posted by WILWAXU
If it's squealing, you may need a new pulley.
I went over kill. I run the Thunder(Katech) tensioner and the deep groove "Larry" pulley.
My belts didn't squeal until after a few high RPM blasts right after the pulley install. I have not had any problems w/ throwing belts though. I've been doing searches trying to find the correct fix.
The adjustable tensioner rocks. But, just because you can adjust the hell out of it, DON'T. Unless you want replace everything connected to that belt because the bearings burned up...then it's cool. The recommended tension can be set with a torque wrench, and is perfect. A lot easier than measuring belt deflection too.
hey LSUxBlake not trying to steal your thread, but man im scared to install pullies cause of all the problems ive read about. lets say im about to install the slps with the 25% crank and the o/d alt. along with a new tensioner. What all needs to be done? I mean torque #'s for bolts..size of belts and what to double check
You don't need the alternator pulley. All it does is overdrive your alternator...it is really only good if you run a high-powered stereo. I have a cam, so my idle is raised. I get the same, if not more charging power now. No problems.
This is exactly what I was concerned about... Messing up stuff by getting it too tight. Could you give us any tips on how you set your belt tention with the torque wrench? It sounds like you got this stuff figured out!
Thanks...
Thanks...
Thanks...
1) tighten the adjuster bolt with your other hand until it is very snug
2) have a friend adjust it until it is very snug
Then set your torque wrench to tighten the adjuster bolt (which will not have moved if you snugged it right) to the torque setting they specify and tighten it. The whole thing took me about 20 minutes by myself. It does NOT come with a new tensioner pulley, which i recommend you buy. It was like $15 at Advance Auto parts.
Actually, I had a friend install my ASP yesterday. I had him do it because he's very experienced in the matter and I didnt want it flying off. The sequence with the new bolt goes 36 ft lbs, then mark the pulley at 12 o clock, and turn it an additional 120 degrees (to around 4:35). It's hard as hell to hit those last 30 degrees or so, but you can get it.
I am pretty sure the directions call for thread locker on the tensioner pulley. I forget on the crank pulley...it has been a little while.
I've heard of people doing it that way before, but I have never seen a good write up on doing the crank pulley that way. You really have to watch and make sure it does on all the way, because 36 ft-lbs isn't alot when you are driving that darn pulley on. I think we got it up to like 145 ft-lbs and I said hell with it, it lines up. I would imagine you do the first run with the old bolt because the bolt must get weakened with all that cranking on it. Then we took out the old bolt, put the new one in and cranked to the torque specified for the last pass in the instructions.
I was actually referring to torquing the new bolt down to 36lbs + 120 degrees. We torqued the pulley on with the old one to 245 ft lbs and then pulled the old one out first.
