bbk throttle body quest.
l just recently replaced my tb with the bbk 80mm and every morning when i drive the car while its not fully warmed up the rpm drops really low when i come to stops. anyone have any ideas whats wrong. the wierd thing is it only does it when i first start the car... only mods are lid, maf sensor, and throttle body.
Originally Posted by Phoenix57
u need to turn up ur idle with the little allen screw. I had the same prob, and that helped.
simple fix, should take care of it. if not, then unplug your battery for 10-15 mins, hook it back up, and then it will re-learn all the tables and everything(since you pretty much wiped all the temporary tables, but not any tuning), and it should teach itself with the new throttle body installed. that should take care of the problem.
