adjustin rockers ?
Old 08-21-2004, 08:56 PM
busavette's Avatar
Default adjustin rockers ?
just finished up H/C& intake in my 2k vette,but forgot to turn over manually& adjust rockers,all buttoned up except for that ,is there another way w/out causing problems(codes),I know to set at 22-24lb. ft,just worried about gettin the correct torque on the open valves as this puts pressure on the rocker??
Old 08-22-2004, 07:52 AM
LS1derfull's Avatar
Question
Adjust each cylinder on TDC following the firing order, adjust slowly to allow lifter bleed down. Is this what you are looking for?
Old 08-22-2004, 07:57 AM
PREDATOR-Z's Avatar
What kind of rockers??
If stock or non adjustables just tork to 22lbs and be done with it.
