408 iron block guys come on in
Old 08-22-2004, 09:42 AM
chrdij's Avatar
Default 408 iron block guys come on in
Got the block shipped last week and the old engine should be out 2morrow. I did notice on a thread that there is a problem with the alternator and would have to be modified in order to fit? I thought it was a direct bolt on? Is the location different on the 6.0 block than the ls1, and how did you get the alternator to fit. Thanks for all help,
Chris
Old 08-22-2004, 10:09 AM
single digit dreamer
parish8's Avatar
i dont think you have to modify anything, just leave one bolt out is all.
Old 08-22-2004, 10:18 AM
chrdij's Avatar
I think I can live without one bolt! Thanks for the input!
Old 08-22-2004, 06:16 PM
romanss's Avatar
Just drill and tap the missing alternator bracket hole. Just don't go too deep. I did mine and there were no problems. I even did it in the car.
Roman
Old 08-22-2004, 06:27 PM
chrdij's Avatar
Drill and tap is the way I will go. The block is out of the car so it should go very smooth. Thanks for the replys
Old 08-22-2004, 06:38 PM
taqwache's Avatar
i drilled and tapped mine also. i used a 3/8 by 16 tap and just used a starter bolt off a SBC. works perfect.
