Drag Racing Tech - air bag! yes or no?
9secpacecar
01-04-2003, 06:10 AM
i am putting in 12 bolt,control arms,trogue arm, hal's fronts and drag springs,rear comp eng. drag shocks,should i use air bag? and what is the part # for single one? and how much air.tia.
ROB'S SS
01-04-2003, 11:27 AM
it would depend on how the car launches. most people would recommend it im sure, but if you dont NEED the airbag, but you would have to play around with it. same as the air pressure in it. trial and error. probably be between 15-20 psi
Skelton
01-09-2003, 06:05 PM
An air bag can still help unless you go with a rear sway bar like the wolfe.
WJ SOM SS
01-09-2003, 06:09 PM
A very in-expensive and quite rewarding mod, if you play around w/air pressure and get it right... it'll help you. WJ. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
kevinb
01-12-2003, 04:48 PM
Where can you get an airbag and how does it install? Can it help out a launch with a car with hypercoil springs in it?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
