Will a truck TB work on a Camaro?
Old 08-24-2004, 09:39 PM
Smallblock's Avatar
Default Will a truck TB work on a Camaro?
I know they're virtually identical except for the coolant tube and the fresh air tube or whatever it is being different. Has anybody used a Truck throttle body on a Camaro or Firebird though?
Old 08-25-2004, 01:47 PM
John_D.'s Avatar
I have one on mine. Bolts up fine. I had to tap the fresh air tube around just a bit. I bypassed the coolant tube, so no biggie there. There are some earlier model truck tb's that are smaller though.... So it depends on the year.
Old 08-25-2004, 01:50 PM
Moderator
jimmyblue's Avatar
I ported a truck TB core for my '02 Camaro SS
and left the original casting untouched, for
sentimental value.
Coolant tubes differ (I cut mine off and bypassed).
Throttle cam is different from the late Fbodies, it's
smaller. I swapped my '02 throttle shaft on and
reused the truck blade.
PCV fresh air nipple is different. I wiggled them both
out with a #2 Phillips down the neck and swapped
the car one on (alternative would be a new hose).
