What length pushrods do I need???
Old 08-24-2004, 11:09 PM
YOOFORMULA's Avatar
Default What length pushrods do I need???
I had my stock LS1 heads hand ported rather extensivley(did not mill heads), put some Patriot dual springs, Comp cams oem replacement lifters, still the ole Hotcam and LS6 valves. Can I still use the 7.400 hardened pushrods I have or do I need something shorter? Thanks!
Old 08-24-2004, 11:53 PM
technical's Avatar
Same cam, same head height, same pushrods. If they worked before, they'll work now.
Old 08-25-2004, 07:44 AM
YOOFORMULA's Avatar
Even if the valves are longer in length? This is the only thing i can think of thats causing the chattering I am hearing once the motor gets warm.
Old 08-25-2004, 07:55 AM
PREDATOR-Z's Avatar
LS6 valves are longer because the LS6 cam has smaller centerlines.
So to cure your chattering you need 7.35 p-rods. right now you have too much preload and your lifters are bottoming out. (Could collapse)
Hope this helps.
Old 08-25-2004, 10:13 AM
YOOFORMULA's Avatar
Thank you!! I just needed to know that I was heading in the right direction!
Old 08-25-2004, 11:55 PM
technical's Avatar
I'm confused, I thought you only had the heads ported? Other than the PP springs and comp lifters, what else did you replace?
Old 08-26-2004, 12:19 AM
YOOFORMULA's Avatar
I added some LS6 valves when they were reassembled since I thought my old ones might have been bent.
Old 08-26-2004, 01:24 AM
technical's Avatar
Ahh, didn't get that from the original post. Sorry 'bout the confusion.
Old 08-26-2004, 09:06 PM
YOOFORMULA's Avatar
No problem. Thanks for the help though, I am reassembling now that the correct size p-rods arrived. Hopefully tonight
