Tci 3600
Old 08-24-2004, 11:13 PM
fivepointseven's Avatar
Default Tci 3600
How would this convertor work on a basically stock 99 TA.
Only mod being ASP pullies and would it be worth it to add 373s or not? I currently have 273s and this is my daily driver.
thanks
Old 08-25-2004, 06:31 AM
Kevin Winstead's Avatar
You'll like the converter, especially with the 2.73 gears. It should pick you up around .6-.7 through the quarter over your current setup. The 3.73 gears will pick you up another .1-.2 as long as you have some sticky tires.
Kevin
Old 08-25-2004, 10:26 AM
koolrayz's Avatar
I had the 2.73's when i bought the SSF3500 and all i can say is WOW. you will love it. It really makes the performance aspect of the car livable and is just fine in a daily driver. I stayed with the 2.73's till i went with the 9"
Old 08-25-2004, 11:16 AM
any problems w/ a 3600 and stock rear?
thanks for the help!
Old 08-25-2004, 01:15 PM
koolrayz's Avatar
not till i went to slicks with nitrous. even then it took the posi out so it peg legged but was still functional
