Oil filter study
Old 08-25-2004, 12:01 AM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default Oil filter study
I got the link to this site:
http://minimopar.knizefamily.net/oilfilterstudy.html
from a racer, engineering client of mine. After reading this article I know why I have lifter noise in the morning. This guy tested Mopar filters but the filter construction will be similar for the Chevy filter. I thought the info would be of interest to just about everyone at the site so I figured I would pass along the link. Make sure and read his "oil filter review" page as well.
Steve Demirjian
Race Engine Development
Sponsor
Old 08-25-2004, 01:14 AM
lsx24's Avatar
Excellent Studies
Old 08-25-2004, 04:31 AM
Patman's Avatar
That study is ancient, try this more recent one:
http://www.oilfilterstudy.com/
Old 08-25-2004, 05:25 PM
lsx24's Avatar
Good Info
Old 08-25-2004, 05:58 PM
FinalTA's Avatar
so, basically, I'll stick with my good ole AC Delco filter. Can't beat it for the price!
Old 08-25-2004, 07:04 PM
Patman's Avatar
Actually you can. The Walmart Supertech is better than the AC Delco, and it's cheaper.
Old 08-25-2004, 07:13 PM
FinalTA's Avatar
better at flow, but not so much on filtration. Is that a correct statement?
Old 08-26-2004, 04:26 AM
Patman's Avatar
Correct, however filtration is not as important on a hard driven car, flow is much more important. If you drive at full throttle a lot, you'll see higher engine wear if you use a filter that does not flow as well.
Old 08-26-2004, 08:11 AM
OWENMUSTANG's Avatar
here's a question...
tpis lists a donaldson endurance filter at $15.00
this does not appear to be the one in the test.
has anybody used this filter?
(side note. i called donaldson, they claim they don't have an endurance filter
for a pf44....)
Old 08-26-2004, 08:51 AM
Moderator
jimmyblue's Avatar
Does the oil pressure sender indicate pressure
upstream, or downstream of the filter in the
LS-1?
Old 08-26-2004, 09:50 AM
JS
JS's Avatar
Patman is correct,most of my racer buddies look to flow before filtration.If u change your oil every 2 to 3 K is doesnt really matter as much about filtration.I run 3QTS 10/30 Valvoline Racing/3QTS of Valoline 10/30 with a KN and have 40PSI at idle and 70PSI under WOT.I just change it out every 3K or if I'm at the track 2 times in a row.
Old 08-26-2004, 04:46 PM
Redlinez's Avatar
Cool. I've been buying those Supertech filters for a while. Today I bought a Parts Plus filter. I forget who they said made it, but it looked well made inside and the gasket was well fastened to the filter.
Old 08-26-2004, 09:26 PM
FinalTA's Avatar
Thanks for the input guys. I guess filtration and flow will always be close to inversely proportional. I don't beat the hell out of my car on a daily basis, and I run longer intervals with my Redline oil. In my case, I'll take the better filtration over flow I suppose....
Old 08-26-2004, 09:39 PM
NHRATA01's Avatar
Patman, I thought at WOT you are buypassing the filter regardless, is that true?
Also does anyone know the answer to JimmyBlue's question - is the oil psi gauge reading upstream or downstream of the filter? If you put a poor flowing filter in there, is the reading going to be higher or lower?
Old 08-26-2004, 10:29 PM
Z06er's Avatar
Check out the AC Delco PF 35L. Cheap, high flow, large capacity and works great with a remote filter mount.
Old 08-27-2004, 12:36 AM
SSDude's Avatar
for a pf44....)
I believe the filter you are referring to is not an Endurance filter. I believe it is the Donaldson P551307. It is the same size as the UPF44 and the PF44. I have used it before.
Old 08-27-2004, 04:13 AM
Patman's Avatar
It is true, however a more restrictive filter will still restrict the flow in the time it takes for the bypass valve in the block to react. So there is still momentary hindrence to flow if you're running a more restrictive filter.
Old 08-27-2004, 05:20 AM
Redlinez's Avatar
The one I bought is made by Trust. Don't know who they are.
Old 08-27-2004, 07:42 AM
if you check out the picture on the tpis site shows a black & gold
filter that says endurance and part of the part number. (F09)
Old 08-27-2004, 10:17 AM
LIMIT's Avatar
K&N enough said!
and throw in 1 quart of 20-50 synthetic, along with the rest and your smooth sailing for 4000 miles.
remeber the old timers never had oil analysis or fancy testing technics.. its like washing your face.. use soap water lather then rinse
this is not what we need to worry about.. the Ls1 is better than that.. unlessyou sustain max lat G for 30 seconds.. yeah ok
Quick Reply: Oil filter study
