the right cam...
the right cam...
i hope i chose the right cam for my new set-up. i went with a 240/244 609/612 @ 113. i put it in a 395ci Lunati stroker. i plan on spraying at least a 175-200 wet shot. the car is a 6-speed.
thats a pretty decent sized cam. sounds about right for cam versus ci growth. that split should work pretty well for the spray. its not as big as the 231/237 as you were runnin, but it should work well anyhow. good luck with the setup, sounds like it should haul some ***.
