Moser 9" sway bar mounts (3" exhaust clamp???)
Moser 9" sway bar mounts (3" exhaust clamp???) and sway bar hitting rearend pumpkin??
I'll be putting a 9" in my car this weekend that I'm buying from a friend. He never ran a sway bar so I need some help. I plan on using my stock 24mm sway bar, but I thought I read something one time about needing different mounts for the axle tubes to attach the swaybar mounts to? Is this right? Can't you use muffler clamps? If so, what? 2.5"? 2.75"? 3"?
Thanks for any help!
*Oh yeah, do I just use 80w90 or 85w90 with GM posi additive? I think it has a Auburn posi in it.
<EDIT> Read my reply down below about the sway bar wanting to hit the lower tq arm mount and the rear of the rearend housing (pumpkin) Any help on fixing this? Can I make spacers to lower the sway bar down more and hopefully away from the problem areas? THANKS!
Originally Posted by Hardtop
I used the BMR weld on sway bar brackets, and poly bushings. I had to use an 1/4" aluminum spacer, between the bracket and the bushing, so the sway bar would clear the torque arm brackets welded on the rear.
Bruce
Bruce
Cool, thanks! I put the 9" in today and used the 3" muffler clamps, but we couldn't get the sway bar mounted b/c it wanted to hit the rearend pumpkin and the lower torque arm mount that Moser welded onto the housing.... you know, one of those little pipe mounts for the tq arm. If I space the sway bar down some, will that fix it? I don't see any other way.
Thanks!
Mine was close, I just rotated the bottom of the muffler clamps a little towards the rear of the car and it cleared - pretty close to the t/a mount on the bottom but it cleared and it hasnt moved in a year. You may have to make some spacers, depends on the bar and style of clamps. Here is a pic of mine..
Thanks!
Thanks!
Bruce
Originally Posted by Fireball
I had to notch the bottom bracket support "pipe" to get mine to clear fully.
Bruce
I bought spacers from Spohn. I thought the u brackets were 3.5" not 3.0 but heck I put it in 4 years ago.
Bruce
Anyone got pics of these spacers?
Bruce
