Which way does water circulate thru the front 4 holes in the block??
As the topic asked, which way does water flow, I know 1 on each side is in and 1 out,which ones are out???
Thanks Ryan,I sold the waterpump off of the 6.0 iron block before I knew which way the water flowed.This is going in a race only set-up fabricating the cooling system and may use a inline waterpump.Anyway THANKS AGAIN!!
