New brand of heads
New brand of heads
Just finished a customers car with a Precision Race Components H/C package.The heads are Stage 2 5.3L heads with a PRC custom 225 camshaft.The following is a list of components that come in the cylinder heads
5.3L castings ( NEW )
PRC Dual springs ( .640 lift ) stock diameter,drop in
140lbs @ 1.800
PRC Titanium retainer
PRC seat bases
steel bodied viton seal
Ferrea 2.055 Intake Valves
Ferrea 1.60 Exhaust Valves
Here is a link to results of these heads.
https://ls1tech.com/forums/dynamometer-results-comparisons/208929-prc-225-cam-prc-stage-2-5-5-3-heads.html
https://ls1tech.com/forums/dynamometer-results-comparisons/207313-tsp-magic-stick-prc-heads-a4-dyno-results.html
The cylinder heads sell for $1529 outright, or 1329 if you supply the cores. The custom cams are $379.00.
140lbs @ 1.800
PRC seat bases
Originally Posted by jermstyle
very nice... what are the flow numbers on the heads? And intake runner size? Specs on the cam?
What compression was the car running that put down 450?
Those are great numbers for such a smallish cam, and the torque is awesome.
Track times are a must! Any pics of the ports on these heads? And what is the intake port volume?
I was rushed installing the heads so I didn't take pics of them, but Terry can make a few of some heads he has. As far as runner volume goes, I was under the impression that they were 215cc range, but don't hold me to that.. Terry can clarify that for sure.
Originally Posted by redc4
Are these heads affiliated in any way with Patriot Performance??????
We need pics, track times and a sound clip.
Also, do you use a super 7 style locker?
The car is FAST!!!! It's sick! Fastest car I have ever ridden in and that was with the cut-out closed losing about 20 RWHP. I have never been that surprised by brute acceleration! Me -->
p.s. Thanks, Scott. Now my T/A seems slow again.
Originally Posted by Redlinez
Awesome heads Terry. Does that conflict with the sale of Patriots? I'm not surfing as much as I used to. Do you have two businesses?
This does not conflict with Patriot,because I no longer work for them.I am fulltime at Racetech Speed.
Yea, I just found out. I guess I only surf when I have money because every time I get on here I see something else better than ever to go faster cheaper!!!! I wish you the best, I'm sure you're somewhat in a tacky kind of situation but apparently as I posted on another relative post, the power goes where you are!!! Too bad you can use 5.7 heads as cores.
140lbs @ 1.800
PRC seat bases
https://ls1tech.com/forums/showthread.php?t=208929
https://ls1tech.com/forums/showthread.php?t=207313
140lbs @ 1.800
PRC seat bases
HOLY CRAP!!!
who said bigger is better
that shows ya its all about volacity
