Need help oil pressure at 0........
Old 08-26-2004, 01:50 PM
1FST99Z's Avatar
Default Need help oil pressure at 0........
I went to start my car this afternoon, and when It started it sounded fine but the oil pressure light was at 0 so I freaked and shut it off... I recently replaced the oil pressure sending unit due to me braking the last one off while swapping to an ls6 intake. so i got the new sending unit and put it back on and now once I started the car the needle on the guage shot to 80.... is that normal. help me out please.
thanks
Wesley
Old 08-26-2004, 01:56 PM
Boostaholic's Avatar
I'm confused, did you just replace the sending unit and got 80psi or is it still 0?
And lots of people break the oil press sending unit when removing their intake manifold.
Old 08-26-2004, 02:05 PM
1FST99Z's Avatar
yeah it was at 0, so then I replaced it and now it shoots up to the peg above 80 even b4 I turn the car over
Old 08-26-2004, 02:09 PM
Tech Addict
Rokko's Avatar
any way to get the wires crossed? wrong sender?
Old 08-26-2004, 02:13 PM
1FST99Z's Avatar
only 1 wire and it only plugs into that particular unit. I thought of that and got to looking.
thanks though
Old 08-26-2004, 03:35 PM
SidewayzOZ's Avatar
Mine pegged out when my sender was broken...but maybe that depends on how you break it. Seems kind of backwards from your case.
Old 08-26-2004, 03:59 PM
1FST99Z's Avatar
yeah it is kinda wierd, b/c it was at 0 then once I replaced the sensor and put it all back together and started it back up it then pegged, also I noticed that it pegs when I just put it in the start position ?????? and doesnt come down at all. I let it run for around 3 minutes and it stayed pegged so anyone who knows the answer to that will be my savior. so much for taking it to the track tommorrow..
Old 08-26-2004, 04:16 PM
1FST99Z's Avatar
I also just went a head and reset the pcm and hopfully I will crank it up now and maybe see a difference
Old 08-26-2004, 04:22 PM
1FST99Z's Avatar
well now it must have reset itself and is now back to 0 on the guage???? what else could it be that would just not have any oil pressure???
Old 08-26-2004, 10:45 PM
SidewayzOZ's Avatar
Hope you didnt break that one too
In case you did I have a proven method to keep from breaking them. Take off the brake booster hose and pull the intake forward enough to get to the sender, remove broken one, place new sender on and torq down with the special socket. Then leave the socket on there and put the intake back on. This forces you to avoid breaking the sending unit b/c it wont move with the socket on there (and it wont break either since the pressure is on the base which is metal and not the plastic). Once the intake is back on then pull the socket off and hook the brake booster and etc back up and plug the sending unit back up. Good luck with finding your problem.
Old 08-27-2004, 04:41 AM
1FST99Z's Avatar
naw, didnt break that one. but only one more thing to change and that is the oil pump. I hope that is it b/c if that isnt it then I am at a loss
Old 08-29-2004, 10:12 PM
1FST99Z's Avatar
guess what it was the oil pump, now it screams... thanks all
Old 08-29-2004, 10:22 PM
SidewayzOZ's Avatar
Good deal, glad to hear youre back up and running
