Idle Questions
Old 08-26-2004, 01:52 PM
slows6's Avatar
Default Idle Questions
I am going to finish up a comp 220/224 530's lift on a 112 tonight and i don't have the $$$ to get computer tuning right away maybe in a week or two when i find a cable that is not 400, anyways....
can i get the car to idle and drive without cpu tuning right away or will i have to tuning before the car will be able to run again???? thanks for the help
Old 08-26-2004, 02:17 PM
jermstyle's Avatar
That cam should idle and run with the stock tune… It wont run as well as it should, but it should run.
It's an M6 anyway, you can keep it alive...
Old 08-26-2004, 02:21 PM
Boostaholic's Avatar
There is a idle adjust screw on your throttle body that will help you set it if you can't get it to run and have no way to tune the pcm
Old 08-26-2004, 02:28 PM
slows6's Avatar
i know there is no way to tune the pcm that is what i am going to do in the next couple of weeks, i was just wondering if i can get it to idle by the screw for now or if immediate tuning would be required?
