What aftermarket cam can I run with stock valvesprings
Old 08-26-2004, 02:28 PM
Dirty Vegas's Avatar
Default What aftermarket cam can I run with stock valvesprings
Well?
Old 08-26-2004, 02:32 PM
jermstyle's Avatar
Why would you select a cam based on your springs?
The following users liked this post:
Y2K_Frenzy (04-05-2024)
Old 08-26-2004, 02:40 PM
ThackerSS's Avatar
Here is a list of the cams you can run on stock springs:
Thank me later.
Coy (04-09-2024)
Old 08-26-2004, 02:44 PM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
There are a few you can run with the Ls6 springs...
Old 08-26-2004, 02:50 PM
I am far too drunk and uncoordinated to put in valve springs.
Old 08-26-2004, 03:15 PM
jermstyle's Avatar
You can install the cam and not the springs? Most shops will install cam and springs for $400.00...
Old 08-26-2004, 03:20 PM
Tranzor's Avatar
If you can't put in valve springs, then you won't be putting an aftermarket cam in, period.
That's like asking for advice on swimming strokes when you're unwilling to get in the water.
Can't swim much without the wet stuff, can't install an aftermarket cam without the valve springs...
Old 08-26-2004, 03:26 PM
2001CamaroGuy's Avatar
NONE! even the stock cam is really to much for the stock valve springs. You can use any of the GM cams with the LS6 valve spring (not your LS1 springs) but none of the "aftermarket" cams (that I know of) can be used with GM valve springs (the ramp rates are too fast/harsh). Even if you go with a GM cam, I would say go on up to the Comp 918 valve spring. That way you not only git some "overkill" for safety but you are also setup to go up to a larger cam if/when you want to.
Old 08-26-2004, 03:32 PM
This is lame. I ran a .525 lift comp cam in my 3.8 V6 with stock valvetrain.
Old 08-26-2004, 04:05 PM
Naked AV
Guest
Posts: n/a
Just because you get away with robbing a bank once doesn't mean robbing banks is smart...
Old 08-26-2004, 07:24 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Maybe in Texas, but not around here- 400 is a bargain.
Dirty Vegas, as for your cam choices for stock springs, you're SOL.
Old 08-26-2004, 07:55 PM
equandt's Avatar
If you don't believe us, put in a T-Rex with some stock springs. Experience is the best teacher.
Don't say we didn't warn you though.
There are a few cams you could swap into your '99 w/ stock springs. Here's the list:
Stock '98 cam
Stock '00 cam
Stock '01 cam
Stock '02 cam (I can sell you one of these if you would like, $75 shipped).
Good luck.
Old 08-26-2004, 09:54 PM
Stock '98 cam
Stock '00 cam
Stock '01 cam
Good luck.
...nice
Old 08-26-2004, 10:40 PM
SeeYaSucker's Avatar
You Could also run an aftermarket cam with stock specs. if you just want to say you have an aftermarket cam.......LOL
Old 08-27-2004, 07:19 AM
J-Rod's Avatar
Correct...
Old 08-27-2004, 07:23 AM
PREDATOR-Z's Avatar
It's all in here,
Old 08-27-2004, 12:00 PM
KRAZY K 2000 TA's Avatar
Default springs
look if your willing to change your cam your willing to preform mods on your motor .springs should be listed as a first for mods on any ls1 motor. they are always floating the valves and week stock bent pushrods are saving your motor
Old 08-27-2004, 12:37 PM
Naked AV
Guest
Posts: n/a
Hey - regarding this comment....
Someone told me to keep the stock pushrods as a 'fuse' for the motor...that if I got aftermarket pushrods that were stronger, I would risk damaging the valves, but if I kept the stock pushrods in, they would go first and it would be cheap to replace. Is this sound thinking?
Old 08-27-2004, 12:49 PM
2xLS1's Avatar
You can only bend pushrods or valves when the springs can not control the valve events as dictated by the cam lobe at a particular rpm.
!LS1 11 Second Club
Not really.
