Smog
Smog
Living in California, I am under the microscope for smog checks. I'm worried about the visual inspection for my "FAST" intake and TB. Anyone had any problems passing the visual because of bolt ons?
1 Post
The visual is for catalytic converters?
From reading your sig, it looks like you should be good to go. I'm sure your shorties have a carb certificate.
What are the full specs on your cam?
They don't release the cam specs. About all I know is the lift is .581 or .589. User #52172 got his h/c done there and they didn't tell him either. I guess they don't want their secret formua out.
Smog shops are supposed to check all parts/mods for CARB numbers. Technically, very few bolt ones are legal. Not even lids are legal due to the fact they do not come with carb numbers. From what I have heard, most shops will not take the time to check for carb numbers. It can be a long tedious process. However, most will check for cats, and make sure they are in the right place.
