bad vibrations when takeing off slowly
i got a new clutch and a new slave and a new rear pinion seal, we installed the rear pinion seal but did not count the treads, i replaced all fluids and put in lsd additive. but from a stop going forward or reverse i get this surging cluncking noise, it stops when i start to move, or when i shift gears even at low rpms it does not make the noise, is this clutch shutter or something in the rear?
