afr w/o wideband, only nose :-)
Old 08-28-2004, 02:39 PM
Sport Side's Avatar
Default afr w/o wideband, only nose :-)
Anyone scaled their IFR table for a rich condition? How much?
No wideband here, but i multiplied all values (3.13) by 110%, and I can still smell a rich mixture coming out of my exhaust. Also, all PE values were decreased by 90%.
Is there any factors I'm over looking? Certain tables that correlate exc.?
When logging, I usually see 950mv's soo I probably have some room to play around with values.
Gonna run some logs tonight. Just wanted to attempt to get my afr somewhat better than stock tune w/ headers.
Thanks,
Kyle
Old 08-28-2004, 07:43 PM
red ws6 99's Avatar
Thanks,
Kyle
What are your Ltrims showing? You want them just slightly negative. The stock o2 are accurate at idle so use them. Never try to adjust your WOT stuff until you get the idle fueling figured out.
Gary
Old 08-28-2004, 07:51 PM
Sport Side's Avatar
I'm averaging -3.013 s trims.
thanks
Old 08-28-2004, 08:05 PM
red ws6 99's Avatar
thanks
Then you are not running rich, the computer is correcting just fine at idle. I have found that even with turbos if the IFR table is correct the car will maintain a 13:1 AFR with the stock AFR table. Without a wideband I would not go leaner than the stock PE table, no matter what the o2 sensors say. You might make more power but not for long.
Gary
Old 08-28-2004, 10:04 PM
Sport Side's Avatar
Gary
hmmm, ill consider that.
i appreciate your help
Old 08-29-2004, 07:59 AM
Billiumss's Avatar
If you don't have cats, welcome to the club of smelly exhausts....
