Stock MAF (Ported) vs Granatelli
Old 08-29-2004, 02:07 AM
Mr Powell's Avatar
Default Stock MAF (Ported) vs Granatelli
Ive been told that a stock MAF is the best route to go. My car is a track car only... The motor is built for nitrous, etc.. I was just wondering if there was a 5-10hp diff between the two. I have both, but I have always had the Granatelli on. Ive been told Im losing HP from it, is that true??
Old 08-29-2004, 08:35 AM
4mula's Avatar
most guys who use after market MAFs end up getting pinging at upper RPMs and set off codes.
Old 08-29-2004, 10:42 AM
Mr Powell's Avatar
Ive never set mine off, atleast I do not think. Any HP diff between the two??
Old 08-29-2004, 10:48 AM
Moderator
jimmyblue's Avatar
Both porting your stocker and using a GMAF put
a mis-calibrated piece onto your motor. If you are
not prepared to tune (and do it without any info
on the true flow/freq for your MAF table), then
you get what you get and it's leaner than stock.
Good combo with nitrous, that.
Old 08-30-2004, 05:47 AM
Mr Powell's Avatar
So as far as power goes.. no signifcant differences????
