Stock lenght of O2 sensor wires, longest to shortest
LS1Tech Administrator
Received 1,471 Likes
I tried a search but came up empty handed....
I wish I had marked all my sensors before I pulled them all like two years ago....
Anyway, all the stock LS1 F-body O2 sensor wires seem to be a different lenght. I know that I was able to use one of them as a substitute for the right front after I put my headers in without needing an extension. I don't recall which it was though. I think I was then able to use another for the driver's side.
Does anyone have any info on the order of wire lenght (longest to shortest) of the stock sensors? Or at least any idea of which are the longest?
Thanks for any help.
Anyone?
Originally Posted by SidewayzOZ
I think rears were longer in some years, but I think for certain years they were all the same length. Curious why you're asking?
As for the reason, when I put my headers on 2+ years ago I pulled all the O2s out of the stock stuff and never marked which was from where. When I put the exhaust together, I just picked the O2s with wires that were the best lenght for the front (didn't use rear sensors) and it turned out that one was a perfect fit for the passenger side without using a O2 extension wire; it was the longest one of the bunch. Now I'm 99% sure that the O2 sensor that I used on the passenger side is not the one that came stock in that location, so I'm not sure which one I'd have to buy/order should I want to replace it.
Any more replies?
Anyone?
Originally Posted by WILWAXU
From what I've been told. All the replacement sensors from GM for our cars are the same length. Only the stock factory stuff was "cut" to length.
