Drag Racing Tech
What PSI to run Nitto's ?
Old 02-10-2003, 06:38 PM
1BadAzzBlkWs6's Avatar
Default What PSI to run Nitto's ?
I am going to be getting the BMR torque arm and lower control arms with the relocation brackets. I'm also getting the 275/40 Nitto's to run. My question is what psi do you guys launch and at what RPM with an M6? Thanks for your help
Old 02-10-2003, 07:04 PM
bspz28's Avatar
Default Re: What PSI to run Nitto's ?
I use to keep mine between 18-22 psi. It depends on track preo and how hard you want to launch ..
Old 02-10-2003, 07:27 PM
F.A.T. PERFORMANCE 01's Avatar
About 18-20 psi.
Old 02-10-2003, 07:31 PM
Chris99WS6PWTMET's Avatar
Mine seem to hook best at 20psi. 1.66 60' lowered, SY3500, 3.73's, TR224, Spohn TA.
Old 02-10-2003, 08:36 PM
racer88's Avatar
18 PSI, nice hot burnout, 4.10 gears 3-3300 launch w/ my M6.
Old 02-10-2003, 10:00 PM
Thanks for the help, Mine has been lowered and I will be ordering the panhard rod also to help. The best 60ft I could get before was a 2.0 with street tires and I lowered the tire pressure to 20psi and got that. So with the Nitto's and the suspension I should see alot better 60ft time. Thanks guys.
Old 02-10-2003, 10:14 PM
BIGBOS's Avatar
I ran them at 18 when I was at the track to try and "hook", I've seen people go lower though... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 02-11-2003, 12:44 AM
LittleBoyBlu99's Avatar
I lower my pressure to 18psi, With good burn out 4-6 seconds i cut 1.60s,and a1.586 Best.Nittos or BFGs. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old 02-11-2003, 07:50 AM
ou812/z28's Avatar
i run 20 on my 315's and hook very good at the track and road.
Old 02-12-2003, 12:09 AM
kent's Avatar
My best results were between 14 to 16 at the track. Come down in increments of one and find the air pressure that best helps you. Cheers.
