Drag Racing Tech - Paging Hoffpauir regarding your 275-60-15 Nitto DR's.
Pro Stock John
02-13-2003, 05:41 PM
How did you like them?
Mike Hoffpauir
02-13-2003, 06:15 PM
These are my daily driver tires.
I went a 1.51 at the Thunder shootout, but you know how awesome that track was. When I was running at State Capital Dragway in the weeks prior to the Thunder race I got a best of a 1.56 out of them. This was an average track..nothing special but had decent traction for no race cars running on it.
I found 20-22 psi to work best. When I went to 15 or so pounds the car would spin at the top of first gear. The car still hooks well both initially and 30 feet out at this psi.
When I had the car at 3500 pounds the tires would rub if I went over a big transition in the road. My car is lowered a little because I pulled the spring perch. But, I normally drive the car around weighing 3350 or so I no longer have this problem.
dug
02-13-2003, 10:22 PM
Mike
How big are they? Calculating the height and width from the numbers come out to 10.8" wide and 28" tall. Does that sound about right?
So Slow
02-14-2003, 07:45 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by dug:
<strong> Mike
How big are they? Calculating the height and width from the numbers come out to 10.8" wide and 28" tall. Does that sound about right? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I measured one recently and it was closer to 27.5 mounted on a car..
Mike Hoffpauir
02-14-2003, 03:56 PM
Dug, Soslow posted the correct height of the tires, and I think your predicted width is a bit generous. It's more like 9 inches...I'm not sure though because I can't find a tape measure around here to save my life :/
Mike Hoffpauir
02-14-2003, 04:01 PM
Hey Scott check this out http://www.ls1tech.com/ubb/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=24&t=002625#000010
Email me if you have any more questions <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Pro Stock John
02-14-2003, 04:02 PM
Mike, think the 275-60-15 Nitto DR's would fit nice on a 15x10 rim? FWIW I had 50's on 15x8's and I don't think they would fit on 15x10's they would be too narrow I might be able to dig up a pic.
Mike Hoffpauir
02-14-2003, 04:31 PM
John, I've never had a 10 inch rim so I cant really answer your question. I do think the tire fits the 8 inch rim fine, but would probably fit great on a set of 9 inch bogarts like Futral has <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . Nitto recommends 7.5-(8.5)-9.5 width rims for this size.
StreetStalkerZ
02-14-2003, 04:44 PM
Thanks mike <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ February 14, 2003, 04:45 PM: Message edited by: StreetStalkerZ ]</small>
So Slow
02-15-2003, 12:36 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by StreetStalkerZ:
[QB] Tim,did you ever order some taller tires? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not yet but I'm going to try a set of 275/60/15's..I'm going to stick with the BFG's but right now I'm deciding on wether to put a wolf bar in the car..I'm getting tired of getting the boot because of not having one...
StreetStalkerZ
02-15-2003, 12:51 AM
Tim,did you ever order some taller tires? On a side note i blew the 4L60E tranny the same run the 10 bolt let go at Hallsville that day you were there. Now the Z is under construction and will be looking to take the #2 cam only spot for now <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Don't worry mike i'll come after your time later this fall when the intake goes on the car <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Mike,can you send me some info and pics of your 4" dual ram air setup?
JimmyKash
02-15-2003, 01:41 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong> Mike, think the 275-60-15 Nitto DR's would fit nice on a 15x10 rim? FWIW I had 50's on 15x8's and I don't think they would fit on 15x10's they would be too narrow I might be able to dig up a pic. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You know with big hp, little tire cars its a pretty neat trick to take your tire and stretch it out over a wider rim to get the maximum amount of tire on the actual ground...
A lot of the ss/o guys run their 28x10.5 on 12" rims
