Just got off the phone with Ken about my 383/ATI plans.. I have some options! HELP!
Ok guys.. As you saw in the other thread here are my plans... Since the car is down...
Stage 1 (Now) Complete Short Block Bottom end...
383 Rotating Assembly...
LS6 Ported Oil Pump
Timing Chain..
Stage 2. WINTER
Head / Cam Package
New Valvetrain
LT Headers
Stage 3 SUMMER
ATI
12 Bolt
here is the thing though...
I know the ATI can only make so much boost..
He suggested either going with 8 to 1 pistons now and pick the H/C package to match that or....
get flat top pistons now which will give me a 10 to 1 comp and just get low compression heads later on to take the compression back down...
If I go with low compression pistons and BIG massivly ported heads will my compression drop below 8 to 1?
Since I'm doing it in stages I wanna do it right..
He said he woudl come up with a plan for the piston and heads combo and call me this morning. I'm just trying to get my own understanding as well.
Any Suggestions...
LS6 Ported Oil Pump
Timing Chain..
Stage 2. WINTER
Head / Cam Package
New Valvetrain
LT Headers
Stage 3 SUMMER
ATI
12 Bolt
Any Suggestions...
I'm getting so stressed I don't know why.. I just wanna make sure i get it right ya know.. I know they know what they're doing they're the only ones I trust.. But ultimately it's my choice on what decisions to make....
Go with the 8.0:1 pistons now. (Reverse Dome)
You will not be able to drop to 8.0:1 with a flat top piston and a hogged out chamber in the head.
What are your power goals? The D1SC should support 675RWHP easily through a six speed. Go with the SDCE tensioner setup and the LARGEST front mount intercooler you can afford.
Good luck,
Chris
Good luck,
Chris
Keep this in mind. your car will be a pooch with the 8:1 naturally aspirated...
add the heads and cam and it will still be a pooch relatively speaking
Forced induction is the only thing to save you.
things never go as planned.
I would go the other way..when the time comes I would use a big head and head gasket to get it down..maybe AFRs with big chambers..
Originally Posted by PHANTA-Z
I have two customers running around with $7k longblocks right now in cars that dont make what a stock version of the same car makes, simply because they went the low comp route and now are short the $5k for a blower setup. Not a good place to be. Hate to rain or your parade, but this is one reason i like nitrous for people who dont have a jillion dollars to play with. If your gonna do a dedicated blower motor, save up until you have enough for the motor AND the blower at the same time. Otherwise im with ^^^^, just do a 10:1 motor (which you can put boost to no problem) and you wont be sorry.
Well Why don't I do the Blower first and then H/C...
My car is not running now.. 3 blown pistons. low compression stroker now..
blower winter..
H/C spring time?
I have to make my decision now!
blower winter..
H/C spring time?
Good luck,
Chris
Good luck,
Chris
You can make decent power on the 8:1 motor with the right heads/cam. Over 400RWHP easily. It'll be fine until you do the blower. You CAN do the 5.3L but I think it is a waste of money. I have seen bigger cube 8:1 motors make anywhere between 400-440RWHP depending on the configuration
Do it right from the beginning. That means full fuel system, BIG injectors, great heads, tuning etc etc.
Have a look at what NOGO is doing. (Kevin)
PM Nogo on the board or post your qestions on the FI section.
You want to keep the comp around 8:1 and size/pulley the blower to flow the cfm you want. NoGo is at ~15#s boost, makes HUGE power and does it on pump gas with no issues at all. There arent many guys making close to 700RWHP on pump gas with a D1 blower. 9:1 is too high imo. Go with 8:1-8.25:1
Well Ken Said he has it all mapped out for me..
He's going to email me his plans this afternoon..
I told him I want a goal of 500-600 HP as a Daily Driver With minimal maintance and heat issues and well he knows his ****..
I trust him so I'll let you guys know what he plans....
Thanks..
Thanks..
With a Supercharger setup i wouldnt go under 9.1 C/R. The lowest i would go would be 8.8 C/R. The reason is because its harder to get boost out of a SC than a turbo. If u had a turbo setup i would have told u 8.0 or 8.5 would be fine. Almost every .1 decrease in C/R is around 8 rwhp lose. So if u went down to 8.0 C/R and u couldnt get 18-19psi out of the D-1SC which is going to be the case then it doesnt make sense to go that low with the C/R. I think the max psi u can get out of a D-1SC on a 383CID will be around 15psi. So a 9.1C/R and 14-15psi would be ideal for such a setup. 16psi on a 8.0C/R will produce less power than 15psi on a 9.1C/R. Also the 9.1C/R will have a faster throttle response than a 8.0 C/R. This is what I'm going with anyways. Good luck.
