What springs will last 30k?
Looking at a TR 224 or Tr 220 with TEA stage 1.5 heads and headers. Is there a spring that can deal with .560 lift for 30k? My car will see 10k a year and I don't feel like changing springs annually. Are there other cams that can make 380-390 rwhp (A4) that are easier on springs?
I imagine even 918's will last - it probably depends on how hard you run the motor.
I'm not sure if any spring out there can be dropped in and not checked for three years... I don't even think the stock ones should, from what I hear.
I'd probably go with 918's and get a spring tester... You'd probably need it regardless??
Call TR and talk with Paul. I'm sure he'll have a good recommendation for you...FWIW, my buddy has been running his TR220 on 918s and has 30k on them without any issues and has no plans of changing them in the near future. IMO big, stiff duals are overkill for a baby cam like that.
When I bought my cam from TR, they told me the 918's should be good almost indefinetly. But still recomended I checked them out every 30k miles. And I have .600" of lift on my intake side.
what do ya know
Code:
Comp CC 918 Single spring 73.1g
Code:
GM 03' Z06 Spring 77.3g
Comp CC 987 1.440 Dual Spring 119.3
Comp CC 772 Stock Dia Tit Ret (918) 7.2
Ferrea E11020 Double Tit Ret 9.4
Comp 1.250 Tit Ret 10.7
GM Stock LS1/LS6 ret 11.3
Victory 1.550 Tit Ret 14.2
Comp CC 730 1.440 Tit Ret 15.9
http://www.totalengineairflow.com/te...ainweights.php
!LS1 11 Second Club
Y'all are forgetting that he's going with TEA 1.5's which probably came with Comp 987's. Those springs have a different diameter than drop in ls1 aftermarket springs. Comp 978's would be a good swap, but the 987's should have no problems with the 224 cam for quite some time.
