copper head gaskets and lower press. rad. cap?
when using copper head gaskets should the radiator cap be replaced with a lower psi cap to run a lower cooling system pressure??
what are the factors affecting this situation? (i.e. coatings , etc.)
Clark copper head gaskets told me to use a 7lb radiator cap. I got it from my local parts store (Napa). They also told me to run straight water for the break in period then put in the anti-freeze.
be lowering the cooling system pressure, you are less likely to have cooland leaking from the passages to the outside of the head or into the oil holes (i.e. lifter openings) .
o a side note, i heard from some one local that if you use block sealer on your leak you will take care of it once and for all. i'm not sure i want to dump some of that stuff in a modern engine like an lsX. anyone care to elaborate on that fact? pro's , cons?
It helps relieve pressure being built up in the motor. My car is mainly for drag racing so I just put the 7lb radiator cap on as a precaution. I also put the tablets GM sells (Ac Delco) to stop leaks.
